Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 conversion for my 77 corvette
Old 03-03-2003, 12:50 PM
LS6power LS6power is offline
It wont be much of a problem except if you run a 700r4 of a newer model car such as an 89 trans am you will need a shift converter because those tranys need a computer. Make sure that you also check your rear end gears. A 3.23 rear end will help your car out on the freeway and also give it a nice jump just in case you feel like putting the pedal to the metal
