Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 conversion for my 77 corvette
Old 03-07-2003, 06:34 AM
airworld2's Avatar
airworld2 airworld2 is offline
82 corvette had 700 r4 in it all parts should be availble from chevy dipstick, and fill tube t/v or kick down cable(depends on what you call it) different,tounge on crossmember might require replacement or change. trans in vett has short output shaft, and tailhousing for drveshaft,but you have to check what you can find on trans parts from local shops, shifter was 3 speed with out low in 82 but you can always replace shifter later
