700r4 converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2005, 01:38 PM
propaneburner's Avatar
Last journal entry: Artillery wheels
700r4 converter
Hello all.
Maybe a stuppid question , but is there a difference in a th350 and a 700r4 converter.
And how to identify them.
Any help info welcome.
Thanks.
Old 11-06-2005, 04:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by propaneburner
Hello all.
Thanks.
the converters are NOT interchangable.
the t-350 converter- pump hub measures 1.873 in diameter ... (larger than a t-700 converter). Chevy style t-350 converts have a bracket for a bolt w/nut design to bolt to the flywheel.
t-700 converter hub is 1.748 in diameter. There are pads on the 700 converter for a metric bolt only to bolt it to the flywheel.... early pads were round , later pads were square / rectangle shape
Old 11-08-2005, 01:04 PM
Thanks Crosley
The metric bolts i new , just forgot it a little.
This and the hub size are just for the 700r4?
I also look for 700r4 info as i want to rebuilt one myself.
It is for my 1956 chevrolet paneltruck, and just built a 383 for it on propane.
Right now there is a 350 in it with a 700r4.
I specialy look for serial numbers for witch trans and converter to look for.
Thanks.
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
700r4 torque converter to flex plate question BR57 Transmission - Rearend 6 10-05-2004 12:41 AM
700R4 torque converter HURSTW25 Transmission - Rearend 3 09-28-2004 07:07 PM
700R4 with slipping converter clutch CleviteKid Transmission - Rearend 1 08-28-2004 05:56 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
