700R4 Converter ALWAYS Locked Up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2011, 01:42 PM
I just put a good lockup torque converter in my truck (came out of my brothers transmission with 50 miles on it).The one I took out never locked up. This one is locked up in ALL gears (1,2,3,4,R). I thought it couldn't lock up in 1 and R. When you put it in gear it kills it. I can put it gear and then start it and it goes fine but you can't stop it without killing the motor (or shifting to N).
The Transmission is in my '72 GMC truck so it has no wires going to the plugin on the side of the transmission.
Any Ideas?
Old 07-13-2011, 04:07 PM
Overdriv's Avatar
Your lockup wiring is not correct or you have a defective converter.
When you installed the converter, did you have to pull the converter to the flywheel 1/4" or so to bolt it together?
Old 07-13-2011, 04:18 PM
SSedan64's Avatar
Either the TCC/TorqueConverterClutch is damaged in the TC/TorqueConverter or the TCC Apply Valve in the Pump is stuck in Lockup position.
Old 07-13-2011, 04:44 PM
I have no wiring. My brother has a 700R4 in a '71 Ford and has no wiring. It works just fine.
I had a small gap when I bolted them together.
Old 07-13-2011, 05:11 PM
sqzbox's Avatar
My pipes are my music
Originally Posted by 1972RedNeck
( This one is locked up in ALL gears (1,2,3,4,R).Any Ideas?
Thats wierd. I couldn't do that with a manual lock up switch if that tells you anything.
Old 07-13-2011, 06:24 PM
The transmission isn't supposed to be able lock up in 1 & R.
Old 07-13-2011, 06:45 PM
Overdriv's Avatar
Let's see, no wiring, other converter would never lock-up (normal).
No wiring, different converter, locked all the time, (not normal).
If that was the only change you did, it seems pretty cut-n-dried to me.
Why did you change the converter in the first place?
There has to be external wiring for the TCC to lock on a 700R4 unless it has been modified to hydraulically lock in OD.
Old 07-13-2011, 08:59 PM
I changed the TC for a higher stall. Is there any way to tell if the transmission has been modified for hydraulic lock up on the outside (line pressures)?
I had (have) a lock up switch. It doesn't do anything with either TC.
Old 07-13-2011, 09:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
here are my thoughts if you wish to read them:
first converter never locked up.
you changed the converter to stall speed - lock up converter. Now the the engine is stalled (killed) when the trans is shifted to any gear.
This tells me the trans pump has been modified for non lock up operation. That explains the first converter never locking up.. and the converter was modified for non lock up operation. Pump and converter must match, if one is modified, the other needs to be.
When a pump is modified for Non lockup, the oil flow direction into the converter is changed. So , now when you start the engine the converter clutch is applied.
Old 07-14-2011, 12:45 AM
SSedan64's Avatar
Yep^^^, forgot about that one. TB.com member had the same problem with a 2004R. Pump was modded for Non-Lockup TC & He installed a Lockup TC.
Old 07-15-2011, 07:12 AM
I just pulled my pan off. There is no solenoid or wiring harness. Does the TCC Valve have to be up or down to be locked up? What would be different inside the pump if it was converted to non lock up operation?
Old 07-15-2011, 04:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Some folks block the lock up valve ''in'' , some block the valve ''in'' and modify the oil passages for better flow with non lock up converter (preferred method)
Some folks buy a transGo kit that replaces the lock up valve and springs completely (best method in my opinion)
I would remove the inner snap ring on the lock valve bore in the pump and see if anything falls out... go from there.
Locked up 350---torque converter bolts vetteman2 Engine 2 03-26-2011 07:23 PM
4l60e torque converter locked acdcontheroad Transmission - Rearend 2 09-14-2010 07:35 PM
torque converter locked up acdcontheroad Transmission - Rearend 5 07-18-2010 06:26 PM
700R4 - RPM with TCC Locked vs Unlocked? ezobens Transmission - Rearend 7 08-24-2008 06:32 PM
turbo 350 torque converter locked up biggy72 Transmission - Rearend 20 06-08-2008 11:14 PM
