700R4 converter lock up - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2006, 05:55 PM
Rough's Avatar
New Member
The converter in my 700R4 seems to delay locking up when cold. It locks up at a higher rpm [maybe 1000 rpm] than when the car is warm. Once the car has been driven a short while and reaches operating temperature it works normally. Any suggestions on what to look at would be appreciated.
Old 12-27-2006, 06:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What type of vehicle? Stock OE vehicle , custom install , street rod?
How is the trans set to lock up the converter clutch?
Hydraulic lock up?
Electric lock up with an internal pressure switch?
How many miles on the trans?
Recent install of this trans?
Repair work on the vehicle recently?
Old 12-27-2006, 06:40 PM
Rough's Avatar
New Member
1993 Camaro, less than 5K miles on the trans, 2800 vigilante converter maybe 1K miles [1/4 mile at a time] on converter, trans otherwise performs well. Thanks.
Old 12-28-2006, 01:18 PM
I know teh 4l60e's will not lockup until either the engine or trans reaches a certain temp.
Since your 1993 car has the 4l60(no E) and has a PCM, I bet its woking normally.
peace
Hog
Diagnosing lock up torque converter inoperation junkyardjeff Transmission - Rearend 0 07-04-2006 07:35 PM
700R4 won't lock up, what part in the trans? LanceM Transmission - Rearend 9 08-16-2005 07:04 PM
Towing in 3rd with a 4th gear lock up kit in 700r4 wed68 Transmission - Rearend 4 03-25-2005 01:34 PM
700R4 torque converter HURSTW25 Transmission - Rearend 3 09-28-2004 08:07 PM
700R4 with slipping converter clutch CleviteKid Transmission - Rearend 1 08-28-2004 06:56 AM
