Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 converter lockup/questions
Old 11-30-2011, 03:49 PM
sbc307's Avatar
sbc307 sbc307 is offline
So all i have todo is run a positive wire to a switch then to the A terminal and just flip the switch whenever i want overdrive to kick in.... correct? No ground needed.... or do i need a ground on terminal D too? I also think i might be a servo problem because 1st to 2nd seems good, deff not too close. im probably pulling the trans out this winter and imma go over it, because i dont know whats done and whats not..................
