Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 converter lockup/questions
Old 12-01-2011, 11:23 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
If you are switching carbs get the correct TV & TV corrector Brackets.
With the Edelbrock linkage the TV pressure rise will be Low= BAD and can burn the Trans up. Your TV Cable Bracket may be Ok with the Edelbrock.
Eddy >> http://www.summitracing.com/parts/SUM-700203/
Holley >> http://www.summitracing.com/parts/SUM-700202/
You should do a Pressure test.
http://www.jakesperformance.com/TV_C...etup_Info.html
http://purplesagetradingpost.com/sum...o/700R4p1.html
Are you using the Factory Tach? If so they are famous for incorrect readings.
With 2.73 gear, 26" tall Tire, 3500rpm you should be running 99mph. in 3rd gear in 4th 141mph. In 2nd gear 61mph.
