700r4 converter will not stay locked up - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2013, 05:16 PM
hey i am having the same troubles have the same set up got a 700r4 with the hydraulic lockup kit from transgo in it having the same problem new tranny new torque converter???? will not hold in lockup unless you let off the gas???
Old 03-26-2013, 06:48 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
adjust your tv cable
Old 03-27-2013, 10:53 AM
I was told that 700's won't stay locked up in 4th if beyond 3/4 throttle. That only the corvette 700's would. Maybe what i was told isn't true, or maybe you have to modify them. That is one of the reasons (plural) that is why i chose the 200-4r. I hope someone with 700 experience will jump in, and tell us why for sure.
Old 03-28-2013, 05:12 PM
it is properly adjusted i dropped the pan a couple of days ago to check and see if solenoid has the checkball in it it does and tv cable is properly adjusted could the o ring on the input shaft be cut slightly or dried up?
Old 03-30-2013, 03:11 PM
could the o ring on the input shaft be damaged from the torque converter install this is driving me up the wall
Old 03-30-2013, 04:07 PM
Built Not Bought
you can put in a corvette servo or a police option servo ,it will stay in at WOT,
Old 03-30-2013, 08:22 PM
idk about corvette servo.... ive got one in mine still downshifts im pretty sure its a valve in the valve body you swap out not just a servo
Old 03-31-2013, 09:04 AM
Years ago, we had the police cars with the 700 r4 in them. we were told then that the trannys were from corvettes and they would stay locked up at high speed. Actualy the motors were the corvette motors also. I believe it has something to do with one of the presure valves in the 4th gears side of the valve body. No tranny expert, i am, i am, so that is why i chose the 200-4r. Actualy i chose it for alot of reason over the 700. We burned up alot of 700 in those years. Actualy, we were lucky, chevrolet replaced them under warrenty. We had one setting at the dealership ready to put in so we wouldn't have no down time,.
Old 03-31-2013, 11:53 AM
There are now 4 sizes of servos,
the smallest was used behind the Inline 4/6 cylinder-8642554
2nd is the V6/V8 servo 8642553
The newest size is used in the 4l70E Police PAckage PPV(Police Persuit Vehicle) Tahoes-24229159
And the standard Corvette servo 8642093
The Corvette used a higher stalling TC, the 1995+ V6 S10's used the same guts in their TC's and code DBLF. Because this TC softens the shifts a tad, GM used a larger apply area Vette servo to firm up the shift. The DBLF L35 1995+ S-10 V^ TC when mounted behond my stock 97 Vortec 350 L31 allows for a brake stall of 2800rpm. A nice boost in launch and reduction in rpm drop during WOT upshifts.
This new 4l70E servo is in between the V6 and Vette servo.
Here is some info from Sonnax
Sonnax - Aftermarket replacement transmission, torque converter, and high performance automotive parts
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
496CHEVY3100 (04-01-2013)
torque converter stays locked up at idle 23 tbucket Transmission - Rearend 5 08-05-2013 09:22 AM
Drag racing 700r4 with lockup converter locked? Fang16 Transmission - Rearend 1 03-28-2013 05:41 AM
700R4 Converter ALWAYS Locked Up 1972RedNeck Transmission - Rearend 11 07-15-2011 04:35 PM
4l60e torque converter locked acdcontheroad Transmission - Rearend 2 09-14-2010 07:35 PM
torque converter locked up acdcontheroad Transmission - Rearend 5 07-18-2010 06:26 PM
