700R4 converter wont unlock - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2007, 09:08 PM
I work at our local chevy dealership and I drive an 84 Silverado and I wanted to buy a new 700 and our tranny guy says I can build you one for a whole lot less, long story short we used a 92 core built it and the converter stays locked up at all times. we have even taken it out and back apart and cant find anything. I haven't even hooked up any electronics yet. Any help???
Old 10-22-2007, 09:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
define: "locked all the time"
when you shift from park to any gear , does the engine die out becasue the converter clutch is applied?
Or the converter clutch locks up as you drive , then does not want to unlock as you stop?
Old 10-22-2007, 09:40 PM
700 wont unlock
The engine doesn't die when I put it in gear but when Im cruising at low speed it sounds like I have a 4 speed manual trans in it and I haven't down shifted, when you almost stop it down shifts back to firtst. The shifting is a little awquard also, but firm. I havent hooked up any of the electronics yet.
Old 10-22-2007, 09:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF you have no electrical hooked to the trans.... some one may have set this trans up for hydraulic lock up.
or
Could be the lock up system is malfunctioning.
Drop the pan to see what is stuff is setup as would help... an experienced after market trans guy would help too.
Many OEM dealer builders are not up on the after market way of things with trannys.
Old 10-22-2007, 09:53 PM
700 wont unlock
What would cause the system to malfuction and what should we look for to see if someone has made it a hydraulic lock up. I drove it home for the first time and I'm tired of tearing this thing apart if you get my drift.
Old 10-23-2007, 06:20 PM
wont unlock
I also heard that you can put a check ball in a certain spot and the tranny will automatically lock up in second, third and fourth gear. Do you know were that might be so I may look to see if mine has one in that spot because that sounds axactly like what mine is doing.
Tuck & Roll Upholstery Mother Interior 17 09-23-2008 09:44 PM
Torque converter drain plug 700r4 blacklabzeke Transmission - Rearend 2 03-21-2007 09:22 AM
700R4 converter lock up Rough Transmission - Rearend 3 12-28-2006 01:18 PM
700R4 torque converter HURSTW25 Transmission - Rearend 3 09-28-2004 08:07 PM
700R4 with slipping converter clutch CleviteKid Transmission - Rearend 1 08-28-2004 06:56 AM
