700r4 convertor lock wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2010, 12:03 PM
Hello everyone I'm new to hotrodders and I have a question concerning 700r4 convertor lockup. I recently installed a 1985 Camaro z28 700r4 into my 1985 s10 w/a350 .The s10 originally had a 700r4 but the external wiring plug was a two wire setup (one from a vacum switch under the hood the other from the brake light switch) The z28 trans has a three wire plug , is it possible to use the existing Blazer set up to correctly control lockup on the Z28 trans?I do still have the wiring pigtail for the Z28 trans. Any help would be greatly appreciated. Thanks
Old 11-13-2010, 12:34 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
You should be able to use the existing brake switch and if it doesn't have a vacuum switch you can get one at jegs.com
Old 11-13-2010, 01:24 PM
700r4 wiring
Thanks for the reply. My s10 blazer is equipped with both a vacum and brake switch I just need to know which wire from the s10blazer goes to which terminal on the Z28 trans and what each wire and terminal controls? Thanks again
Old 11-13-2010, 06:13 PM
spinn's Avatar
The commons switched rigs are the purple wire from the brake switch is fed +12. The green wire off the firewall vacuum switch is grounded. Controlling these parameters governs the TCC behavior on / off.
Old 11-14-2010, 06:06 AM
700r4 wiring
Thanks for the response, I see the brake light switch supplies 12+ to the purple wire on the trans ,any advice on which one of the other two wires(color or location) would I use for the vacuum switch wire and what is the third wires use? Thanks for the help
Old 11-14-2010, 08:51 AM
octanejunkie's Avatar
Registered Looser
Last journal entry: Background: why I am here
The vacuum switch connects to Terminal A on the trans and energizes lockup. You will want to interrupt it when braking to disable lockup
According to the instructions that came wtih my 700 regarding the connector on the trans:
Terminal A takes 12v fused power
Terminal B is not used
Terminal C no pin present in many 700s
Terminal D takes an optional, manual locking switch
If using a Bosch relay, which is suggested, wire the relay as follows
Terminal 30 takes a fused 12v switched power source, on w IGN
Terminal 85 goes to ground
Terminal 86 is spliced into your brake light
Terminal 87 is not used
Terminal 87a connects to Terminal A on the trans
If using a vacuum switch, splice it inline with 87a that goes to terminal A
I like the idea of automatic lockup over a vacuum switch, in which case a GM style brake switch can be used to interrupt the power going to Terminal A on the trans, otherwise
If you want a manual lockup switch, to lock the trans for towing etc, splice it between with the wire that goes to Terminal D from Terminal A
The pinout of the 4-pin connector on the trans is usually as follows
Terminals A and B are ajacent to the locking tab and face the front of the vehicle, Terminal D is next to, or behind Terminal A, Terminal C, at the 2:00 position, is blank towards the rear of the vehicle. Here is a pic
Old 11-14-2010, 09:02 AM
700r4 convertor lockup wiring
Thanks for the info, like they say a picture is worth a thousand words. I actually think I can solve this now. I very much appreciate your time and knowledge
700R4 lockup wiring. Is this horse dead? qwkswede Transmission - Rearend 8 01-20-2010 09:26 AM
simple wiring for 700r4 grumpy1 Transmission - Rearend 6 11-18-2009 01:54 PM
700r4 trans and lockup wiring Ragtoptoo Transmission - Rearend 1 10-25-2009 07:42 AM
Redneck-rigged VSS wiring question for 700R4 Mad Maggot Transmission - Rearend 1 02-21-2006 08:49 AM
700r4 parts and lockup wiring McDeuce Transmission - Rearend 17 12-17-2003 07:52 PM
