700r4 coolant lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2012, 07:20 PM
700r4 coolant lines
I am putting a 700R4 in a 68 Firebird with a 400. Since the 700r4 was not available back then for a comaro or Firebird, are there trans coolant lines from a newer application that will fit or any companies that offer them for this modification in my firebird?
Old 07-09-2012, 06:41 AM
Last journal entry: Still running strong
Its probably best to make them,because if you got some off another car you would end up cutting,flaring,& bending them anyway.And use steel tubing only.I remade mine an ran them between the inner & outter fender.
Old 07-09-2012, 07:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you had a TH350 in there before, the lines from it will fit the 700. Or if you want to use prebent lines, use the lines for a TH350.
I find it easier to attach the cooler lines to the tranny before putting the tranny all the way up in the trans tunnel.
BTW, the cooler lines at the tranny are:
Top line = into the tranny from the cooler
Bottom line = out of the tranny to the cooler
700r4 has coolant in it; have a question 0pyders Transmission - Rearend 3 09-02-2011 09:09 PM
700R4 cooling lines RickyDoors Transmission - Rearend 1 10-05-2010 10:37 PM
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 04:37 PM
tranny coolant lines SBC4ME Transmission - Rearend 1 07-27-2007 11:29 PM
Intake coolant lines highstick Engine 7 05-23-2004 12:14 PM
