700r4 downshift.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2009, 10:14 AM
700r4 downshift....
I have a rebuilt 700r4 with 500 miles on it behind a stock 283 and 3.50:1 rear gear ratio in my 56 Pickup. TV is adjusted correctly / geometry is correct / shifts great. Tranny fluid is full ; measured when hot in Park.
When I am in 4th and lockup engaged at ..oh say 65 mph... and do a sudden lane change without moving the gas pedal; it will shift down into 3rd momentarily and then back into 4th.
Why?
Old 04-13-2009, 04:46 PM
usmcsawgunner's Avatar
do you tap the brake during lane change?
Old 04-13-2009, 05:21 PM
no. and I do not have the lockup electrics routed thru the brake switch.....I have a B&M controller.
Old 04-14-2009, 05:16 AM
will it do it any other time or in this specific scenario?
Old 04-14-2009, 05:38 AM
I have not experienced the downshift from quick lane changes in any other gear.....just 4th. And it does not downshift from any other unusual action.
My new 700R4 locomark Transmission - Rearend 11 07-05-2007 11:17 PM
700r4 no downshift njbloodline666 Transmission - Rearend 7 07-23-2006 02:46 PM
700r4 slow / delayed 3-2 downshift eliotmansfield Transmission - Rearend 2 06-01-2005 09:29 AM
700r4 3-2 downshift timing MudBoggn Transmission - Rearend 0 04-17-2005 09:21 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
