700R4 and Dual Quads Or Tri Power - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2005, 04:02 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Have this idea of maybe putting dual quads or tri power on the coupe, just curious if anyones using a 700r4 on these setups was wondering how the tv cable was attached to carb linkage Thanks
Old 03-13-2005, 07:35 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you will have to fab up brackets for them I would guess. Or modify some aftermarket mounts.
you could also fab up something to attach to the throttle pedal so the TV cable is hidden from view if you have an open engine compartment.
the same rules apply for the TV cable pull and angles for proper operation the 700 tranny...
the thread at the top of the page may help you. there are links there.
