700R4 end play? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2005, 01:28 PM
Rough's Avatar
New Member
700R4 end play?
When I assembled the input drum on my 700R4 trans I found that I need a thinner selective plate for the forward clutch pack as the clearance is only about .005, I ordered the thinner plate and in the meantime I decided to mock up the drum & pump to see how everything fit together in the case. After I installed the pump into the case I found that I don't have any end play on the output shaft although I used the thinnest selective washer under the bearing. Now for the question, does the forward clutch pack clearance or lack of, have an effect on the end play of the input drum?
Thank you,
Max
Old 06-04-2005, 06:33 PM
Crosley's Avatar
Wiki Edits: 1659
=========== nope
On the forward clutch pack clearance , there are thick and thin steels availible to open clearance up.
Are you building an early drum or late design?
Thank you,
Max
Old 06-04-2005, 08:32 PM
Rough's Avatar
New Member
Late design, any suggestions as to what I might have done to lose the end play? It had about .015 before I took it apart.
Old 06-04-2005, 09:01 PM
Crosley's Avatar
Wiki Edits: 1659
installed something wrong?
different / new thrust washers?
Change any hard parts? Reverse input drum, torrington bearings, fresh bushings?
sealing rings giving a false "no clearance" indication?
Old 06-04-2005, 11:56 PM
Rough's Avatar
New Member
I should have checked the forward clearance before I disassembled, live and learn, I did measure the old & new steels & frictions and they were both about the same thickness could it have been set up that tight [.005]?
New bushings,new GM reverse drum, new washers & bearings, also both planets, sunshell & changed to bearing design reaction carrier shaft.
I'm going to recheck now that you suggested false no clearance.... might be with all the new parts.
Old 06-05-2005, 09:23 AM
Crosley's Avatar
Wiki Edits: 1659
If you changed all those hard parts ( new or used) .... all bets are off for the original selective to be correct.
Did you buy new FWD steels? stack the used FWD steels together, hold them up to a light and look at them on the edge....... any wavey ( non flat ) steels there?
FWD Steels are .010 to .012 different from early to late design. Frictions too....... mix them up and there is little or tooo much clearance.
Sometimes kits supply incorrect parts.... hard to beleive but true.
Old 06-05-2005, 07:03 PM
Rough's Avatar
New Member
I did use new steels .090 [with the original wave plate] and they are the same thickness as the old ones, I put it together today minus the band and I have about .014 -.015 end play.
I'm just going to run the selective over a piece of emery cloth to pick up another 1 or 2 thousandths and go with it. I still don't understand how the forward clearance is so tight when everything I replaced is close to the same thickness, I should have measured the old stack clearance before I removed it.
Old 06-05-2005, 09:11 PM
Crosley's Avatar
Wiki Edits: 1659
frictions measure the same?
early late designs.
early and late design on the pressure plate for the over run frictions too.
Old 06-06-2005, 03:22 PM
Rough's Avatar
New Member
The new forward frictions were each about .005 thicker which I figure was due to the wear on the old ones, I reused the pressure plate on the overruns.
I'll also double check the difference between the old & new overrun frictions & steels.
Old 06-12-2005, 08:32 PM
Rough's Avatar
New Member
After I installed the trans today I ran it through the gears a few times while it was still in the air then I took a drive and it seems to be working well. Quick shifts that get progressively firmer with more throttle. I need some advice as to the proper break-in procedure. I'd like to go to the races next weekend but not at the expense of my fresh rebuild. Also, I have a line lock that I use when I heat my drag radials, and I'd like to know if I should continue to use 1st gear to do this.
Thanks for your help.
Max
700R4 vs 2004R Busted Knuckles Transmission - Rearend 9 12-05-2003 11:20 AM
Ring End Gap bpd411 Engine 3 02-26-2003 09:19 AM
700r4 tranny and gears in rear end RiceMuncherdude Transmission - Rearend 7 02-21-2003 06:09 PM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 06:34 AM
Rear end for 67 Firebird 400 pringles Transmission - Rearend 5 10-09-2001 08:07 PM
