700r4 first gear slip - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2006, 07:46 AM
njbloodline666's Avatar
I Love VTec
within the last week my 700r4 has started slipping at the top of first gear at WOT (4500 rpm or so), my fluid level and tv cable adjustment are correct. is my trans done, or is there something i can do to save it. maybe a shift kit, a fulid additive or a manual valvebody... im assuming a manual valve body will give me a higher line pressure. im in no position to buy a new trans, and i need this car to get me to work so a rebuild is out of the question.
Old 11-05-2006, 09:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
easiest thing to do is ( I am serious) to drive the vehicle slower , easier. IF the car is a daily driver needed for basic transportation , drive it easy so it lasts.
IF the tranny is going away , a bandaid will not fix it.
Old 11-05-2006, 10:20 AM
I Love VTec
i guess you have a point
Old 11-05-2006, 10:24 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
The transmissions demise is forthcoming...once mine started slipping it was less than 2 days - barely got it home and had to have it towed to the transmission shop...
I'd get it to a mechanic you trust ASAP!
700R4. No 2nd Gear, Slips in OD CedarGrove Transmission - Rearend 3 07-29-2006 12:00 AM
700R4/4L60 3rd Gear Slip Questions ih1974d1100 Transmission - Rearend 5 06-19-2006 04:27 PM
700r4 3rd gear slip broken Transmission - Rearend 7 03-15-2005 12:25 PM
700R4 stuck in First gear redvette Transmission - Rearend 3 02-13-2005 09:12 PM
Best gear ratio when installing 700r4 transmission agordon Transmission - Rearend 6 02-18-2003 08:05 AM
