700r4 fluid direction of flow - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2011, 12:30 AM
I have installed a Cad 472 in my '77 Jeep J20 3/4 ton pickup with a th400 transmission. I am now installing a 700r4 trans. and an auxiliary cooler. I need to know which cooling connection on the transmission is in and which is out. Any help will be greatly appreciated.
Old 04-06-2011, 02:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Upper trans fitting is the return from the cooler into the tranny.
Lower trans fitting is the cooler feed from the tranny. So- OUT the bottom, IN the top.
Old 04-07-2011, 04:03 AM
SSedan64's Avatar
Cooler Line Chart>> http://www.transmissioncenter.org/Au...Goes_Where.htm
Old 04-07-2011, 05:10 AM
old yukon's Avatar
So for the 700 r4 and the 4L60e bottom outlet hot and top inlet cold ( click on image with bypass set up)
Does that sound right?
Name:	tranny cooler lines with hot and cold.jpg
Old 04-07-2011, 09:48 PM
SSedan64's Avatar
Yes, just like the Pic.
Most all RWD GM's are like this, the 2004R is reversed.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
700R4 fluid flow pittbull7934 Transmission - Rearend 2 09-19-2009 12:49 PM
what direction does water flow on a sbc 327 Mr. Wormy Engine 8 08-20-2006 09:47 AM
Radiator flow direction cboy Engine 6 10-07-2004 09:43 AM
Heater Core flow direction garretthes Engine 12 09-26-2004 08:09 PM
water flow direction earp Engine 7 02-29-2004 01:20 AM
