IDLE
Park 80. R 120 N 180 4 80 3 80 2 180 1 180 WHEN IN GEAR IT WILL ONLY COME UP ABOUT 10 MORE LBS . IF I PULL THE CABLE ALL THE WAY OUT WHILE IN GEAR AT 1500 RPM IT DOESN'T CHANGE. I PULLED ON IT SEVERALTIMES AND NO CHANGE. ANY IDEAS |
after looking over your pressure readings, it should have the same pressure in "N" and it does in park. except for neutral, the rest of your pressure readings look to be ok, id check the boost valve and pressure regulator valve and make sure that they are not stuck or worn out, with the symptoms your explaining. |
This is a rebuilt trans p & n are 80 my mistake.the trans was built to hold 400 HP at least that's what I ask for . I have adjusted the tv cable a lot trying to get the shift points at 1 15-20 mph in 1 gear I could only get 12mph .max . So I went to go and run my car in a wrt mile 1 gear hooked 2 gear hooked I shifted to 3rd and it wasn't there I let off and it shifted so I'm trying to save the tranny and my motor. Don't know if this means any thing but when I jacked my car up on drivers. Side the servo cover is leaking pretty good
odds are with insufficient line rise, that the 3-4 clutches are already toast. |
It Only Does It At High Rpms WHEN I SHIFT IT.. It Seems Fine In Normal Driving It Just Shift EARLY . IT DOESN'T REALLY SEEM TO SLIP JUST DOESN'T SEEM TO ENGAGE
this trans needs to have proper line rise in order for it not to burn it up. the full throttle shifts without enough line pressure rise will burn the trans up. |
hey man, i fully understand that feeling. but, look at it this way, wouldnt you rather it be right than to just say itll work for now??? |
| How do you run line pressure test on a 4l60e ? | old yukon | Transmission - Rearend | 5 | 05-28-2011 07:56 PM |
| 700r4 Quit Working With No Warning? 91 Model No Fluid Pressure. | a_cmc_2b | Transmission - Rearend | 6 | 10-06-2010 05:56 AM |
| Transmission fluid pressure | sexypizzaman | Transmission - Rearend | 2 | 05-06-2008 09:54 PM |
| 700R4 Line pressure test | 123pugsy | Transmission - Rearend | 6 | 03-30-2008 12:18 PM |
| 200R4 Pressure Test | MI2600 | Transmission - Rearend | 5 | 12-18-2006 06:10 PM |
