700r4 is fluid routed to cooler when TCC is off - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2006, 06:03 AM
Found this statement:
"For reliability the TCC can not remain locked under heavy load. The
TCC is not designed to handle a high load. Also note that the GM
700R4 (4L60) transmission does not route fluid to the cooler unless
the TCC is locked.
in this article:
http://diy-efi.org/gmecm/papers/tcc.txt
I thought the fluid was always routed through the cooler - anyone?
Old 02-12-2006, 10:11 AM
This statement is wrong.
The cooler circuit is active during all stages of use in 700R4.
The converter circuit changes when lockup occurs, but the cooler circuit functions before and after lockup.
Pull off a cooler line if you don't believe it.
Plan on using LOTS of floor dry for the mess....
Old 02-12-2006, 03:13 PM
That's what I thought.
Thanks,
Eliot.
Old 02-12-2006, 06:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I have a vision of a few messy floors.
700R4 tranny cooler....I need one. KeithB123 Transmission - Rearend 11 08-14-2005 10:48 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
TH350 fluid flow in cooler Jmark Transmission - Rearend 2 04-27-2004 07:14 AM
700r4 cooler chevcamz28newbie Transmission - Rearend 1 08-17-2003 09:40 AM
Brake Fluid Cooler CptBil Suspension - Brakes - Steering 2 10-18-2002 03:03 PM
