700R4 Front seal leak over 65mph - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2012, 12:30 PM
blacklabzeke's Avatar
I have a 1993 700r4 that just started leaking out of the front inspection cover (dropped cover and full of fluid). The funny thing is that it only leaks when the the fluid is full and at highway speeds over 65 to 70. If I leave it 1 1/2 - 2 qts low or just below the dipstick reading there is no leak. Just would like some input before pulling the trans and replacing the front seal and pump bushing. Thanks in advance.
Old 07-17-2012, 08:53 AM
Just looking for some input on what would cause an intermittent front seal leak.
Old 07-21-2012, 08:40 PM
have you tried checking vent ontop of trans and check bolts on pump had 94 doing much the same tietend pump bolts it stoped maybe help you to
700r4, transmission
SBC Front pan seal leak Richard H. Engine 10 03-16-2007 01:44 AM
700R4 rear seal leak 55 BELAIR Transmission - Rearend 2 04-03-2006 08:13 PM
turbo 350 leak, front seal area 72chevelle Transmission - Rearend 5 06-03-2004 07:32 PM
700R4 front seal KeithB123 Transmission - Rearend 2 09-19-2003 09:44 PM
350 front seal oil leak buddy Engine 4 08-29-2002 06:25 AM
