700r4 gap of flex plate to converter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2017, 02:12 PM
arnoldsel's Avatar
Reading a watched a video on installs of the torque converter. I have a 700R4. Installed it with new Converter and I bought the thicker Scat Flex plate.
They show that you need 3/16" space between. What if you have less like 1/8" or slightly less. I cannot get my fingers between the back of the converter and the trans making sure the converter is seated into the pump. I am thinking since I did put in the thicker Flex plate that has tightened the gap?
Will this be OK? I could turn the converter with my had easily and that is suppose to mean it is seat. Just a tighter gap.
Old 02-16-2017, 06:10 PM
ericnova72's Avatar
More for Less Racer
If you've got at least 1/16" of gap you've got enough clearance to be okay, when there is zero clearance is when you've got a problem.
I have never liked that 3/16" of free space figure that is thrown around, to me it puts you dangerously close to the two pump drive lugs pulling free of the drive tangs on the gear....I always shim my converter to flexplate bolt locations to get the clearance down to 1/8" or less.
Flex plate Weight hitting Block Plate jdwest711 Engine 0 11-07-2015 12:24 AM
Flex plate/Torque converter dilligaf Transmission - Rearend 0 12-15-2011 12:14 PM
flex plate & torque converter gt43 Transmission - Rearend 2 01-12-2010 07:25 PM
Flex Plate Holes Dont Match Torque Converter mightycarlo10 Transmission - Rearend 3 03-07-2008 07:37 PM
700r4 torque converter to flex plate question BR57 Transmission - Rearend 6 10-05-2004 01:41 AM
