700r4 Gushing Transfluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2006, 08:43 AM
I Just Bought An 89 Blazer With 700r4 As My Next Project. The Other Owner Said It Needed A Transmission There Is Large Amounts Of Fluid Pouring Out Of Ft End Of Trans. If You Fill Trans Up Everything Works Great For 45 Secs To A Min Then Its All Down Hill. I Know There Is A Pump Seal Up Ft And But Will It Leak That Much That Quick. I Expect You Guys To Know Exactly What The Problem Is. Thanks For Any Advice.
Old 01-29-2006, 09:35 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Well exactly where is is coming out of
front seal?
Dip stick tube?
transmission fluid input & exhaust lines
Down shift cable{if applicable}
Pan Gasket
The pump is right behind the front seal so if thats shot yea it will puke fluid like a mother F%#@ER!
Where is it coming from ?
Clean it off add some fluid & A catch pan & try to Isolate it than let me know OK
Pictures really help if you have a camera
R
"SlowRide66"
"Illegitimis non carborundum"
Old 01-29-2006, 09:50 AM
BOBCRMAN@aol.com's Avatar
GM had problems with the 700 pushing out the front seal. They added a small brace to hold it in. Sometimes this is left off and the trans will pop the seal out.. Leaks fluid out as fast as you can add it!!.
Old 01-29-2006, 10:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Perhaps a leaking pump seal or a cracked converter hub is the problem.
lets say it is the front seal leaking problem on the 700 pump.
The external seal retaining braket is a bandaid fix at best.
The proper procedure is to disassemble the tranny. Check the drain back hole behind the seal. it should be near 1/4" diameter. A 1989 trany should have the larger drain hole passage behind the seal.
Then drill the matching drain hole in the pump cover (stator support) , this hole is usuually small for some reason.
Check the pump bushing location... has it moved forward into the seal? If not then replace the pump bushing and seal. Drive bushing out the rear of the pump, push new bushing in fron the rear also! IF the bushing has moved forward , then you need to grind two notches on the inside of the pump housing and stake the new bushing into place
Check the converter hub for cracks and wear. A worn hub will still allow too much fluid past it with a new pump bushing.
Old 01-29-2006, 07:33 PM
You Guys Rock
I DIDNT THINK ID GET A COHERENT RESPONSE BUT YOU GUYS KNOW WHATS UP. ILL PULL THE TRANS AND LET YOU KNOW WHAT HAPPENED. THANKS ALOT
Old 02-20-2006, 02:22 PM
Rob Keller's Avatar
Wiki Edits: 38
so how'd you make out???
R
"SlowRide66"
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 08:05 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
700r4 stock stall? Caesar_Mikey Transmission - Rearend 1 03-27-2005 05:52 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 07:59 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
