700r4 help-any chevy guys? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2006, 09:51 PM
briansansone's Avatar
4 chevys and a ford
I got a bad rebuild that has never worked right. I had decided to drive it until
it failed and then replace it with a unit from a reputable builder. I have always done all my own mechanics except transmissions, but now i'm learning. The transmission has never shifted right. The transmission suffers from very specific problems and I bet someone familiar with the unit will know my problem and hopefully a solution. Like I said I was going to drive it to death,but a massive leak just developed and I have to do something now. I would like to remove the transmission and attempt to fix the leak and possibly its shifting problems. My first question is can I go into the front of the unit and replace the seal at the input shaft without disassembling the whole thing? The haynes manual I have goes through the rebuild proceeder and the pump is only removed after disassembling allot of other parts. I'm pretty sure that is where the leak is. Assuming the leak is fixable and not related to a serious endplay problem, I would like to try to fix the shift problems. Heres how it goes. upshifting ONLY shifts at 15mph (1-2), 25mph (2-3), and 55mph (3-4) .After upshifting I can back off the speed and the appropriate gear stays engaged. All downshifting seems to work good.If I
accelerate with light throttle the transmission slams into gear very hard. If I accelerate with moderate throttle the gears shift firm-feels good. If I floor it first gear is good, second never fully engages-it slips all the through the rpm range, and third catches and feels good. Upshifting always happens at the same speed and rpm-never changes....ever. What I theorize,from reading books and internet articles,is that my throttle valve is stuck telling the transmission the throttle is wide open all the time, and something is wrong with the 2-4 band and it is not clamping tight enough. Any hope for me? I drive the transmission very easy- I don't let it slip or slam into gear-I drive with moderate throttle everywhere I go . There is less than 5000 miles on the unit. any advice would be much appreciated. Thanks
Old 02-22-2006, 10:34 PM
Briansansone,
First off what year 700 are we talking about? If it is an older one then you can go through the TV cable adjustment steps and that will help, but if it is a newer transmission then the computer recieves signals from the transmission that tells it when is the best time for the shift points.
Second isn't there some kind of warnanty with this overhaul you had done 5000 miles ago?!?!?!?
Now on to the front seal replacement. Yes this can be done without taking the transmission apart but it will need to come out of the vehical. But you will want to check the torque converter hub also to see if it has a grooves in it. If it is rough then you will need to buy a rebuilt converter too and more than likely a new front bushing as well.
Good Luck
Scholman
Old 02-24-2006, 07:33 AM
New Member
I could use some help also
you indicated that at some point in year that the computer controlled the shift points. can you advise as to what year that was. My son has a 1987 transam and he is having problems with his much like this gentleman is
Old 02-24-2006, 01:24 PM
4 chevys and a ford
The trans is from a 88 chevy 1500. Throttle cable adjustments do nothing.
I think the throttle valve is stuck in the wide open position. I believe the 4l60E was introduced in 91. mine is just a 4l60. Thanks for the input
Old 02-24-2006, 01:30 PM
4 chevys and a ford
I took my truck back to Mr Transmission ( buford highway, atlanta) about
10 times. They never fixed it and I got tired of not having my truck for
weeks at a time. It should be illeagal to run a business so poorly. Franchise
HQ never even responded to my complaints. At one point they tried to deny my warranty and I had to get a lawyer to make them honor it.
fitting a blower to 359 chevy with 700r4 tranny 37 chevy Engine 6 05-25-2006 08:37 AM
700r4 stock stall? Caesar_Mikey Transmission - Rearend 1 03-27-2005 05:52 PM
Chevy guys look. HemmiGremmie Engine 6 02-20-2005 02:51 PM
Studebaker and Chevy guys... 46stude General Rodding Tech 4 11-14-2004 08:09 AM
Chevy Thunder and stonedchihuahua Jon Hotrodders Site Suggestions and Help 56 03-14-2004 06:47 PM
