Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 Help SBC rebuild
Old 01-18-2013, 03:17 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
It sounds like the TC/TorqueConverter isn't fully installed into the Trans. Most likely the TC Hub lugs/splines aren't in the Pump Gear Lugs.
You need to spin & push in on the TC when installing it. The Input Shaft, Stator Support & Pump splines need to engage. Normally hear/feel 3-clicks/clunks.
Do Not use the Bellhousing Bolts to pull the Trans up to Engine, this will break the Pump gear/rotor.
TC Install Info:
Torque Converter Installation Instructions
Automatic Transmission & Torque Converter FAQ - TCIŽ Auto
Make sure your Flexplate bolt pattern will align with the TC bolt pattern. Some have dual bolt patterns but, some don't & wont fit.
The Following User Says Thank You to SSedan64 For This Useful Post:
ricoramos (01-21-2013)
