700r4 Help SBC rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2013, 01:16 PM
I had a SBC350 TBI engine with a one piece rear main seal and a 700r4 trans. I got rid of the old engine and now have a freshly rebuilt carburated 350 with a 2 piece rear main seal, that I think came off a 1970's vehicle but im not sure what kind.
I finished putting the engine togother and was ready to attach the trany so I can finaly drop it my my 66 c10 ... but then I hit a wall
I placed the original 700r4 torque converted on the tranny and im pretty sure I sat it all the way in, when I try and connect the bell housing to new engine the torque converted presses againts the flywheel and wont turn. Is there a different torque converter? Or what am I doing wrong. The flywheel in using is the one that came with the 2 piece rearmain seal engine,
Old 01-18-2013, 03:17 AM
SSedan64's Avatar
It sounds like the TC/TorqueConverter isn't fully installed into the Trans. Most likely the TC Hub lugs/splines aren't in the Pump Gear Lugs.
You need to spin & push in on the TC when installing it. The Input Shaft, Stator Support & Pump splines need to engage. Normally hear/feel 3-clicks/clunks.
Do Not use the Bellhousing Bolts to pull the Trans up to Engine, this will break the Pump gear/rotor.
TC Install Info:
Torque Converter Installation Instructions
Automatic Transmission & Torque Converter FAQ - TCI® Auto
Make sure your Flexplate bolt pattern will align with the TC bolt pattern. Some have dual bolt patterns but, some don't & wont fit.
The Following User Says Thank You to SSedan64 For This Useful Post:
ricoramos (01-21-2013)
Old 01-21-2013, 10:04 AM
Thanks you where right the torque converter wasnt seated properly
sbc wont move freely after rebuild rebuild. nskeeter99 Engine 9 12-10-2012 05:37 PM
700r4 after rebuild mafiacustomz Transmission - Rearend 9 06-12-2012 01:44 PM
700R4 out of an 84 K5 .... first rebuild junkbike Transmission - Rearend 6 03-23-2009 09:45 AM
700r4 rebuild trimax Transmission - Rearend 3 09-21-2007 09:49 AM
700R4 rebuild Rough Transmission - Rearend 8 05-01-2005 04:43 PM
