700r4 holding gears way too long - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2011, 12:28 PM
my current rig is a 92 chevy 2500 with a solid axle conversion, the trans just started acting funny. i can leave one stop sign and it will shift correctly and firm, then leave the next sign or light and it will hold first to about 35, second till 45, third till 65. the tv cable is not tight. fluid is were is should be, and is not burnt. im lost lol
Old 11-17-2011, 12:59 PM
SSedan64's Avatar
Sounds like a problem with the TV/ThrottleValve, binding/sticking. Usually worse after the Trans gets warm/hot. Can cause high/firm or low/soft shift points.
http://www.sonnax.com/product-lines/...ion/parts/1614
Sometimes giving the TV cable several quick jerks & releases with Engine idling can free it up or clear trash/debri causing the binding.
Old 11-18-2011, 12:27 PM
i played with the tv cable, i got it adjusted right and it was working fine. however it went back to the first problem about 20 miles down the road. i have a feeling the teeth that hold it in place are broke or worn to it wont stay in place very long.
Old 11-18-2011, 05:01 PM
SSedan64's Avatar
Ratchet teeth on the adjuster worn?
Need a new TV Cable.
TV Cable adjustment >> http://purplesagetradingpost.com/sum...o/700R4p1.html
Driving it with the TV Cable too loose can burn the Trans clutches.
How long are gears good for satdiver1 Transmission - Rearend 3 02-19-2011 11:57 AM
700R4 Double downshift not holding Wac Transmission - Rearend 3 03-07-2010 07:33 AM
700r4 .. no 3rd or 4th gears deel2u Transmission - Rearend 2 12-27-2006 09:49 AM
700r4 has no 3rd or 4th gears mattgabe Transmission - Rearend 5 06-27-2006 07:59 PM
Tooo long of burnout??? Lower Gears??? 63wagon Transmission - Rearend 11 08-08-2004 02:13 AM
