700r4 with Holley Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2005, 06:30 AM
snod83's Avatar
I was wondering if it is possible to install the dentent cable to the passengers side of a holley carb with some custom made bracketry? My reason for asking is that my cable is too short to reach the drivers side, and in order to change it I would have to pull my entire exhaust system including the header, and I am not really wanting to do that. I have the specs for the angle that the cable needs to be pulled and such, so I think I can figure it out, but I was wondering if anyone has tried this or sees any problem with doing this.
Thanks for your input,
Ryan
Old 06-28-2005, 07:55 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
The pivot point of the TV cable has to be a certain distance from the pivot point of the main throttle shaft, it shouldn't matter at all which side of the carb it is mounted to.
Let us know what you need to do to get this working for you (take pics and such so others can learn from your experience).
Holley Carb mr.Pinto Engine 5 07-27-2004 04:46 AM
What holley 750cfm carb to go with ??? FiefSS Hotrodding Basics 17 09-29-2003 03:58 PM
Holley Carb Tuning Coleman396 Engine 4 07-19-2003 10:03 AM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
Proform replacement for Holley carb body, worth it? Pinardi Engine 2 01-07-2003 05:51 PM
