700r4 How to change the TV valves? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2013, 09:22 AM
how to change tv valve
Old 06-07-2013, 07:22 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Remove the trans pan.
Remove the valve body from the trans case.
Change the TV valves
Reverse procedure for installation
how hard is it to change stator on 700R4 pump? 350cruiser Transmission - Rearend 1 05-07-2012 12:12 AM
700r4 noisy after converter change Project89 Transmission - Rearend 3 04-09-2012 05:51 PM
700r4 - No pressure change garari Transmission - Rearend 10 11-29-2011 09:29 PM
700r4 change over bobandros Transmission - Rearend 2 03-20-2011 07:35 AM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
