700r4 iden codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2006, 12:45 PM
700r4 iden codes
the one i pulled out had 2 litters ya the one i put in had mzm is this a 4l60e and will not work, little more info the ya is out of 1984 full size wagon the new trans has the identification code of mzm the old trans was ya i read that two letter codes or 700r4 the three letter code is 4l60 just trying to find out if there is 4l60 and a 4l60e i know the 4l60 will not work the problem is what trans do i have
Old 03-25-2006, 06:07 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
make , model , year please.
Explain a bit more of what you need information on.
Your post does not make sense to me.
Old 03-25-2006, 09:11 PM
You don't make any sense, the 4l60e will bolt up and is basically the same inside, but the electronic controls on it are going to be impossible to make work without an aftermarket computer.
Why switch from the 700 anyways? Its a good transmission, we build at least 2 4l60e's a week.
Brendan
Old 03-26-2006, 08:16 AM
Jmark's Avatar
Here is my take on the above statement.
The transmission that I removed from my car has this letter code on it, "YA".
I purchased a transmission that has the letter code "MZM" on it. Is this transmission a 4L60E? and will it work in my car?
Mark
Old 03-27-2006, 07:28 PM
the trans is out of a 84 full size wagon
the new trans i think is a 88 model unknow but it"s going to the shop today thank s for the help
Old 03-27-2006, 07:44 PM
how do u tell a 700r4 from the 4L60
IS THERE A 4L60 AND A 4L60E trans's how do u tell them apart that is is what i am trying to find out and the name of a book on these trans and the ford 4r55e trans thank
Old 03-27-2006, 08:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the 4L60 has a electrical connector on the drivers side behind / above the shifter linkage, it is square with 4 holes in it.
4L60E has an electrical connector on the passenger side. About 1.25 inches round, several contact pins in it.
ATSG manuals are very good for these trannys mentioned..... Google ASTG manual... there will be many links for you to explore.
Old 03-27-2006, 08:06 PM
thank
that is what i was looking for thanks AGAIN
Old 03-28-2006, 07:53 PM
now something on ford trans
1996 explorer V6 4r55e trans is slipping 2 to3 i tighten the 3to 4 band 1/2 turn it helped some but , someone tells me it could be servo seals need replaced what do u think or should i replace the trans,
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
700R4 with Vortec Computer Controlled Engine capps Transmission - Rearend 2 07-30-2005 02:17 PM
700r4 stock stall? Caesar_Mikey Transmission - Rearend 1 03-27-2005 05:52 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
