700r4 Input Shaft/Drum Interchangable to 4l65E Shaft/Drum?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2003, 12:06 AM
I ve heard this rumour and it sounds like a good upgrade, has anyone done this before?? I know the 4L65E have the hardened shaft and drum right from factory. Thanks Fern
Old 12-31-2003, 06:46 AM
airworld2's Avatar
4l65e input drum
you didn't post what year 700? pre87 700 have orifice style drum (shaft), haven't seen different shaft in those(4l65e) yet but I'll guess it was a upgrade on the drum. the only changes I have noticed was gear train upgrades which have there good and bad points...
Old 12-31-2003, 07:06 AM
Crosley's Avatar
Wiki Edits: 1659
Cool
It would help to know what year 700r4 or 4L60E? you are talking about.
In 1999 the 4L60E was changed to a longer input shaft & stator support when the converter was redesigned. Late 1998 is when this happened as I recall (dont quote me). The input splines are moved to the end of the shaft where the O-ring was at in the old design.
The spline location, O-ring location , length are all changed on the late 3 piece case 4L60E and the 4L65E. The removable bell housing is a different depth from the early 3 piece case with the old design input shaft.
With that said , I have photos of the splined area of the 4L65E input shaft with the splined area snapped off from a Magna-charged 6.0 motor from a GMC Denali.
The Aluminum drum, I see little difference in the 4L65E stuff
The 5 pinion planets in a 4L65E..... I have seen (2) broken main casting of the rear planets. They show'd no signs of lost lube, so why they broke....... I don't know. The casting does look lighter duty IMHO.
You rarely see a broken 4 pinion front planet of a 700r4 unless the lube was lost. Then the thrust washers on the pinion gears melt out, things move around and tear up stuff.
I have never seen a broken main body of a 4 pinion 'rear' planet. They have been severly beaten , gears completely rounded off from lost lube, but never seen a broken main body of the planet it's self.
I am guessing you want to update an earlier 700r4 (pre-1992?).... the 4L65E shaft will not retro-fit.
IF this link functions, it is a pic of a 4L65E shaft that is broken, it snapped off at the O-ring groove... could be a new problem area in the future? :
Tony
Old 01-01-2004, 04:06 PM
67 Nova 400sbc.4L60
Broken Input shaft.
I have seen one broken turbine shaft on a 4T45 E broken exactly the same as your picture (at the O ring groove).It turned out to be not heat treated properly. I can't remember what was the reason. If it was a issue in the future you would think it would be around the same build date at least.
