usually the vette servo kits have the 2 O-rings and the 2 sealing rings.
Reuse the sealing ring on the OD piston , it will be fine the larger OD servos are billet units , not a cast piece like the vette servo. More money for the billet piece These servos do nothing to the clutches , it works on the band only
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I'll re-use the OD servo ring if I don't spring for a billet OD kit. Billet vs cast hadn't occurred to me for pricing... Okay so these 2-4 apply servos just actuate the band quicker for a faster shift, therefore less clutch slip during the shift, and a tad lower let's say city driving fluid temps right? So the info around the 'net about 300lbs more apply force in 2nd gear seems incorrect then... Would you still recommend a cheapo vette cast kit for an old 700R4 while she's out waiting to be installed? It's hot down here and I'd like to do what I can for longevity (quicker shifts I suppose). Thanks again! |
300 lbs of additional holding power for the vette servo? I don't know about that.
The vette servo has more surface area to produce more holding force on the band. You will see/feel a firmer 1-2 shift and the 2-3 shift will quicken up a tad also
| AOD into mustang | Stangman196700 | Transmission - Rearend | 3 | 12-16-2004 08:51 PM |
