700r4 INTERNAL HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2006, 07:38 PM
700r4 INTERNAL HELP
My 1st post here. I have a 700r4 with a non lock up converter. The TV valve is set up properly and all gears shift as intended, well they did.
Problem after a day of hard driving I am having reverse problem. The problem is a lite almost gear crunch when going into park from reverse. Also in reverse only I have a knock type noise. The actual damage occured when I went from reverse into drive. All else is fine. The park brake seams to be working properly but it kind of has a little more slack??
Any help would be appreciated. I really hope it can be fixed in the car?? Parking pawl? Thanks
Old 06-11-2006, 04:58 AM
RookiePerformance's Avatar
SOLT8KER
Sounds like a rebuild
Man does that tranny have some problems ... What you have to do is drop the tranny and take it into a tranny shop that you trust. You either messed up the clutch pack in the tranny or you could of snapped the band. It is that or something else very serious, if i were you i would just drop the tranny and get it rebuilt, but to save yourself some money dont drive it cuz it would damage it even more.
Old 06-11-2006, 12:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sounds like a problem with rear planetary unit.
remove and tear it down for inspection is one option.
Old 06-12-2006, 01:53 AM
Drewnashty's Avatar
sitis nam accelero
When I go from park to reverse in my '92, I get a loud clunk most of the time. Not to be confused with a crunch.
V6 or V8 700R4 swap? cacsmret Transmission - Rearend 4 05-05-2006 10:28 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
700r4 wiring questions murrsue Transmission - Rearend 4 02-04-2005 11:09 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 08:59 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
