700r4 internal parts ID questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2013, 07:41 PM
I took apart my 700r4 before I got the rebuild guide.. Been gone for a while just now getting back to the trans.. its telling me to inspect the governor but im not sure what I'm looking for
Old 08-27-2013, 06:05 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.
I edited the thread title. We dont use : "Help, Need Help" as thread titles here.
Placing proper information in thread titles helps the members and the search feature of the board.
Old 08-28-2013, 01:33 AM
Wiki Edits: 85
Adding to what Crosley said, if a poster is too lazy to put a decent description in the title, the poster will find that many, if not most, of the people that can help will ignore the thread.
For example, my forte is transmissions. If you have a transmission problem and the title does not indicate that, I will not read the thread. My time is too valuable to waste reading threads unrelated to transmissions and I don't have the time to read every "Help" thread to find threads about transmissions.
So, if you want the best and most answers to a question, make your title come out and grab us. Saying just "Help" tells us you are too lazy to help us help you, so we will return the favor and be too lazy to help you.
Old 08-28-2013, 06:01 AM
Grand Master of the Universe
Have you tried Google? Also, if the rebuild guide you've got isn't more detailed than "Inspect governor", I'd try another guide.
Never had a 700 apart, but it seems to me it should be pretty easy to find an exploded diagram on-line.
Edit: Found a governor for sale on ebay ($13.00), with a photograph.
Old 08-28-2013, 06:59 AM
Last journal entry: Still running strong
It is or was under the round dome shaped cover. Has weights that extend outwards when spining. Most likely they are wanting you to look at the green plastic gear on the end, check for broken teeth on the gear, also check the plumger/piston inside of it for full movement when you extend the weights by hand
700r4 internal parts damage mafiacustomz Transmission - Rearend 16 02-08-2012 09:53 AM
700r4 trans parts questions 91lss10 Transmission - Rearend 2 03-27-2011 06:44 PM
700R4 Rebuild Parts and Advise Questions wild_man84 Transmission - Rearend 37 04-09-2010 05:07 PM
questions on some 700R4 parts Overdriv Transmission - Rearend 4 03-16-2009 08:35 PM
Internal tailgate parts swb70 Hotrodders' Lounge 1 12-17-2003 09:18 PM
