700r4 issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2006, 02:24 PM
New Member
700r4 issue
I swapped the engine and carb in my sons 85 TA from a 305 to a 350. The carb was computer driven on the 305 and is now an eldebrock non-computer. I am having problems with the trans (700r4) now in that when it shifts to second it goes out of gear then when it revs back down it goes back into first. I have tried shifting through the gears as well with no avail. I am wondering if I need to change the TV cable out on this thing. Any help would be appreciated.
Old 08-18-2006, 08:13 PM
TV issues are everyhting to this trans!!!
The cable relationship and the rate of opening dictates TV pressure and resulting trans performance.
Check the carb linkage first. Ensure that the carb is going WOT, then that trans TV cable is pulled tight at WOT. DO THE CARB CHECK FIRST!! The TV cable adjustment is secondary to correct carb throttle linkage adjustment.
If all that was changed is the engine, the cable adjustment and carb ratio is the problem...
700r4 TV Cable Problem jack71 Transmission - Rearend 7 10-25-2006 08:05 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
700R4 with Vortec Computer Controlled Engine capps Transmission - Rearend 2 07-30-2005 02:17 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
700R4 vs. 2004R 81ElCaminoGuy Transmission - Rearend 2 08-21-2002 01:10 AM
