700r4, just went out. weird symptoms - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2006, 06:39 PM
Sagacious's Avatar
Do you feel like we do?
just got the nova back from the shop with the fresh 700r4 build. took the car out for a cruise and went about 10-15 miles or so. all of a sudden i could rev to 4 grand and the car would barely move, then it slowly lost the gear completely. so i pulled into a parking lot quickly and turned the car off. i checked the tranny oil.. it was full and the fluid wasn't burnt. i waited about 10 minutes went in the store and came back out and started the car. i put it in reverse and backed out and put it in drive and went to the parking lot across the street at which point it started to "lose the gear" again and slip away. every time i turn the car off and let it sit and restart it all the gears engage again but only last for so long. is this something simple like a pressure problem--pump went out? it's all under warranty and is back in the shop but is sitting there due to the holidays and i thought someone could shed some light on this. thanks.
Old 11-24-2006, 08:22 PM
Sounds like it stripped the turbine hub spline in the torque converter. Quality, performance rebuilt converters use steel turbine hubs.
If this is not the issue you may have a filter problem (plugged or fell out of pump). This is a little less likely unless there is a trans pan issue.....
Old 11-25-2006, 04:45 PM
Sagacious's Avatar
yea hopefully its just the torque converter. what would be a trans pan issue.....?
Old 11-25-2006, 11:57 PM
If the pan is not the stock steel pan, there may be an issue with filter support. If the filter is not supported by the pan it will fall out of the pump.
Old 11-26-2006, 02:20 PM
scrot's Avatar
I bet you are low on fluid
I know you said it is full, but with fresh fluid the level can be very hard to read on the dipstick. Try over and over to read the level on the dipstick.
I bet you are 2-3 qts low.
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 07:53 AM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
700R4 no OD weird andrewhotrod Transmission - Rearend 5 07-16-2004 07:17 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 08:59 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
