Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 line bias valve and pressure regulator.
Old 02-13-2013, 09:45 AM
TexasT's Avatar
TexasT TexasT is offline
Did you ever wonder?
Last journal entry: A little follow up
While not specific to the 700r4 here is an article about the 2004r and the principles are similar..
gmay98p7
I wouldn't block it open as it introduces a part throttle harshness. Stiffer spring would be the direction I would go. The hydramatic engineers spent untold time designing the system, and it can deliver smooth part throttle and crisp full throttle shifts if adjusted properly for your situation.
