Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 line bias valve and pressure regulator.
  #20 (permalink)
Old 03-12-2013, 08:57 AM
Kawabuggy Kawabuggy is offline
ASE doc, typically when the low planet set is bad it will make a high pitched whine in 1st gear only, and the noise will immediately stop as soon as it shifts into 2nd gear. If you have a noise that spans both gears you may have something else going on.
