Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Line Pressure
Old 12-28-2012, 11:30 AM
Edgar86 Edgar86 is offline
Thank you for your suggestions, it is possible that the TV is stuck (although I made certain it was free during the rebuild). I have checked the cable, it is not too tight... I find it strange that the pressure is at a constant 150 PSI in the forward gears; since (I think) the TV pressure & pressure routed by the governor "fight" each other to make each shift. I believe I should see poor shifting due to no pressure change when the TV is applied. I am worried that I will not have enough pressure during WOT...possibly burning my clutches.
