Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Line Pressure
Old 12-28-2012, 03:34 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
minimum cable setting on the TV cable is important if the 'fail safe' check ball is in the valve body. This check ball is larger than the other .250 sized check balls.
The trans in fail safe mode will operate at full line pressure, shifts will be late like WOT . You seem to describe this symptom
