700R4 Line pressure test - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2008, 02:41 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I just finished rebuilding a 700r4 (supposedly) and the maximum line pressure I got in all gears with regular and full TV cable pull is 50 lbs.
Any thoughts ?
Old 03-29-2008, 03:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Any thoughts ?
too low... very minimum should be around 65-75 psi , hot
Old 03-29-2008, 06:46 PM
123pugsy's Avatar
Wiki Edits: 29
Thanks for the great advice Crosley. With this I deduced that the TV Boost valve was installed backwards. I opened her up and sure enough it was. I shoved it back together and the whole pressure regulator valve got blown out into the pan. Opened her up again and stretched out the circlip and reinstalled it,put it in reverse and pressure went up and dropped to zero. I think it blew out again but I've had enough for today. I will open it up again in the morning.
Old 03-30-2008, 08:42 AM
123pugsy's Avatar
Wiki Edits: 29
I've got the valve back in properly ( I think) , pressure is up but now it won't shift out of 1st and in 1st feels a bit spongy. Reverse engages firmly.. The engine also lopes when I put it in gear.????
Old 03-30-2008, 08:47 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
boost valve must remain in position in the pump for pressure. Sitting in the pan is not good,
not up shift? TV cable adjusted? Minimum adjustment is important too IF the fail safe check ball is installed.
Worn TV bore can cause "false fail safe" condition to.
Governor is stuck = no shifts.
Governor gear broken = no shifts
Old 03-30-2008, 01:15 PM
123pugsy's Avatar
Wiki Edits: 29
Got it! It was the boost valve not inserted correctly or jammed up. I guess I was too frustrated and tried to rush it.
Shifts really good now and huge improvement over the TH350.
Thanks,
Pugsy
Old 03-30-2008, 01:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
good news to hear / read.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
2000 Buick tranny shifting weird? frankenvette Engine 6 06-13-2006 08:28 PM
Electrical test for 700r4 AngliaBob Transmission - Rearend 1 06-05-2005 06:54 PM
Drive test 700r4 Blackdog Transmission - Rearend 3 05-20-2005 10:21 AM
