Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Line pressure test
Old 03-29-2008, 05:46 PM
123pugsy's Avatar
123pugsy 123pugsy is offline
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by Crosley
too low... very minimum should be around 65-75 psi , hot
Thanks for the great advice Crosley. With this I deduced that the TV Boost valve was installed backwards. I opened her up and sure enough it was. I shoved it back together and the whole pressure regulator valve got blown out into the pan. Opened her up again and stretched out the circlip and reinstalled it,put it in reverse and pressure went up and dropped to zero. I think it blew out again but I've had enough for today. I will open it up again in the morning.
