Originally Posted by 123pugsy
I've got the valve back in properly ( I think) , pressure is up but now it won't shift out of 1st and in 1st feels a bit spongy. Reverse engages firmly.. The engine also lopes when I put it in gear.????
boost valve must remain in position in the pump for pressure. Sitting in the pan is not good,
not up shift? TV cable adjusted? Minimum adjustment is important too IF the fail safe check ball is installed.
Worn TV bore can cause "false fail safe" condition to.
Governor is stuck = no shifts.
Governor gear broken = no shifts
