700R4 Lock up switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2010, 06:04 PM
Could i wire a toggle switch with 12V and use it for the lock up and switch it manually?
Old 02-09-2010, 07:36 PM
Yes, but you need to keep track of it. Coming to a stop with it on will stall the engine. Trying to start the engine with the clutch engaged and the tranny in park is real hard on the starter's gears.
Bogie
Old 02-10-2010, 03:43 PM
thanks
Thank you for the help
Old 02-10-2010, 03:58 PM
SSedan64's Avatar
Lot of Lockup Info & wiring Diagrams here>> http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
Old 02-10-2010, 07:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
in a 700 trans , there is no lock up oil provided till 2nd gearby design. The trans should not stall the engine at a stop if the switch to the solenoid is on.
Some guys stick a check ball in the lock up solenoid snout to have lock up with out electric hook-up. The trans locks up the converter clutch as soon as the shift to second gear happens
Old 05-14-2013, 09:30 AM
I know this thread is three years old but Im looking to do the same thing to my 700r4. Could someone tell me which wires on the outside of the case I need to hook up a toggle? one is fused 12v with a toggle and one is ground and what is the last one? Mine's got three wires
Old 05-15-2013, 01:56 PM
Did you read post #4?
peace
Hog
700R4 wiring to only lock up in 4th? tom1234 Transmission - Rearend 2 08-23-2009 05:26 PM
700r4 lock up problems, engine dies lowandslow65 Transmission - Rearend 10 08-12-2009 07:30 PM
700r4 lock up confusion jrs22166 Transmission - Rearend 4 07-28-2009 09:35 AM
700R4 converter lock up Rough Transmission - Rearend 3 12-28-2006 01:18 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
