700r4 Lockup - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2008, 10:40 PM
700r4 Lockup
I have a 1950 F1 with a SBC 350. It had a powerglide and I am changing the tranny to a 1985 Corvette 700r4. I am trying to find some easy ways to set up the lockup. I have seen kits, solenoids, 1 wire, 2 wire, mechanical electrical, vacuum, no vacuum. Which ones are quick and easy. This 700 does not seem to have a vacuum port and has a 4 prong plug for the lockup. Also will the Detent cable for the powerglide work with the 700r4. Any suggestion on mounts. This has two two parallel bolts for mounts.
Old 07-05-2008, 10:57 PM
48ChryslerRodder's Avatar
Stuck in the past.
Read this post,
The Chevy TH-700R4 Transmission.
then check this from the Wiki knowledge base.
http://www.crankshaftcoalition.com/w...ssions#THM700R
Hope this helps you.
Old 07-05-2008, 11:20 PM
Overdriv's Avatar
As a suggestion for a solution to the lockup, this is the kit I used;TCI
I used this wiring schematic to make it more versatile. I wouldn't pay to much attention to the colors as they are specific to my vehicle.
As a suggestion for the TV cable, no, the powerglide detent cable won't work. I'd suggest you go to here and read up on their EZTV system. Works great on mine. I'd use it again.
Are you talking about the rear mount?
Hope this helps, ask questions if you need more.
Old 07-26-2008, 06:41 PM
700r4 lockup setup
I have read many complicated ways to hook up a lockup for a 700r4. I need a simple explanation of how to use the four prong pigtail from the tranny( 1985 corvette, 700r4 and 350sbc) to the brake switch. Which wires go where? I heard it can be done without inside wiring or vacuum. Please help. I have the pigtail and brake switch.
Old 07-30-2008, 10:17 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
http://www.hotrodders.com/clusters/TH-700R4.html
R
"SlowRide66"
"Illegitimis non carborundum"
Old 07-30-2008, 10:34 PM
SSedan64's Avatar
Read through this thread>
700r4 lock or unlock t converter
Old 07-30-2008, 10:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Hook 12 volts to the "A" hole in the 4 hole connector.
hook a ground wire to the "D" terminal... that may work on an early trans wire harness(internal) you have.
the Corvette trans has a shorter output shaft. I would suggest using a tail housing that has the mount holes - surface built in for a standard trans mount.
the out put shaft will not protrude out of the end of the tail housing like a standard length shaft does.
Image of the tail housing on a vette trans:
Old 07-31-2008, 01:29 PM
Overdriv's Avatar
The TCI kit, and others, lets you install and forget. Which is what you want with a woman driving it. You don't have to install the switches or the relay as in my diagram.
The vacuum switch in TCI's kit is adjustable to your engine vacuum and your driving habits and conditions.
The TCI kit comes with great instructions and is not hard to do. While you are in there you can change the trans filter also.
Old 08-03-2008, 07:37 AM
Hotwire's Avatar
General L33
A simplified break down of Overdriv's schematic:
Make sure pin D is connected to ground. Pin A goes to power that is on when the key is on, except when the brakes are applied. He wired the relay so it disconnects +12V from Pin A when the brakes are pressed to de-energize the torque converter solenoid in the transmission.
Some vehicles have the wire already on the brake switch, but I doubt your 1950 Ford does, so you'll have to wire up a relay like Overdriv did above.
Get a accessory relay from any parts store, but make sure it is a Single Pole Double Throw (SPDT) relay. It will have a 87 pin and a 87a pin.
Referencing the schematic above, connect the following pins up. I'm changing Overdriv's schematic, he wired the relay differently, but you get the same results, mine is just a little more standardized;
85 to your brake lights
86 to ground
30 to switched power (ignition switch)
87a to pin A of transmission
87 is not connected
87a will have power until the brake switch is pressed.
87 will not have power until the brake switch is pressed, so if you wanted to put a third brake light or anything of that nature on your truck, this would be the perfect place to connect it.
Hope this helps!
Jeff
Old 08-04-2008, 01:23 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Guys all good info here.
But why the heck are you using a relay when the TC solenoid only draws around 1 amp @14v...?
A standard 1157 bulb only draws around 1.9 amps with both elements lit. OEM's run the brake light circuit through a NC momentary switch...
But hey... that's just me..
Old 08-04-2008, 02:19 PM
Hotwire's Avatar
General L33
The relay is to "reverse" the polarity of the brake light signal. The OEMs you are talking about didn't have the same switch back in the 50's. He could probably retrofit a newer style switch in place of the original, but I do not know what he already has got. The relay signal is powered UNTIL the brakes are pressed. So brake light on, TCC off. Brake light off, TCC on.
If a brake switch from a S-10 will fit in there, I can tell him exactly how to wire it up, but in the meantime, the relay is the short term answer.
Old 08-04-2008, 02:23 PM
C-10's Avatar
Revolution Calling
Order a brake switch for a GM car/truck with a TH700R4. Problem solved. Auto parts stores readily stock them.
700r4 lockup confusion SeattlesBestCustoms Electrical 3 06-18-2008 02:49 AM
700r4 manual lockup switch Boosted89RS Transmission - Rearend 8 03-25-2008 11:52 AM
700r4 lockup engaged directly after shift into second?? ferociousd Transmission - Rearend 3 07-22-2007 10:32 PM
700r4 lockup? holoffs Transmission - Rearend 5 05-15-2007 02:07 PM
700r4 lockup runn141 Transmission - Rearend 3 09-06-2006 07:40 AM
