You can connect a toggle switch between the yellow and purple wires
This will lock your torque only if you turn on your toggle and on 4th and if the brake is not pressed
x2 on the google, if your starting from scratch? 700r4 tcc wiring pics - Bing images
depending on the pressure switches in the trans?? many many different ways to wire it up..
if your car has the 700 wiring already?
just add a toggle switch in the wire from the brake light switch..
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
