700r4 lockup, 81 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2003, 02:14 PM
New Member
Question 700r4 lockup, 81 camaro
First off, I am very happy to be a new member of this board and most of the posts i do will be about an 81 camaro berlinetta that i recently acquired. I am doing a trans swap cause the T350 came apart on me and i have a 700 laying around the shop that im at, OK.......Will i still need to wire a lock-up switch if i replace a lock-up type 81' 350 turbo with a lock-up type 84' 700r4 out of a camaro, same 4 prong plug and all just wondering if i still need the lock-up switch kit. Thanks
Old 05-25-2003, 06:59 AM
67 Nova 400sbc.4L60
Post
Yes you do.First to keep the torque converter cool while in fourth gear, and second to save fuel while cruising.
