700r4 lockup - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2006, 07:29 PM
700r4 lockup
anybody useing a lockup kit.the ones that change 4th lock up . to not have to use a switch on dash.does it when in 4th gear.
Old 02-19-2006, 08:37 PM
Use the 4th gear pulse switch on the valve body to control solenoid function.
Depending on the type of solenoid wiring, you can control either the 12v+ or ground side. If there are 2 wires on the solenoid itself, use the ground side of the solenoid (black wire). Use a one prong 4th gear pulse switch wired to the ground side of the solenoid. 4th gear pressure will ground the switch, thus the solenoid will be grounded. If there is one wire to the solenoid, use a 2 prong 4th gear switch and split the power (12v+) thru the switch. One prong to the 12v+ source, the second to the solenoid. 4th gear pressure will close the switch providing power to the solenoid. The solenoid is grounded at the solenoid frame (made that way). These scenarios work every time.
Old 02-20-2006, 07:00 AM
lockup
i guess what i was trying to say which kit? they vary from 19.95 to 120.00.i`am doing a full rebuild and it is going in 1963 gmc surburan.it will driven on street only.quadrajet mild 454.thanks i hope this makes sense i just had kidney stones removed. i can not do much but i can play on p.c.
Old 02-20-2006, 10:47 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
I used a TCI 376600 kit in my TH700R4. It was around $100 I think.
This eliminates the need for an ECM to control converter lock-up.
TCI web site is http://www.tciauto.com.
The kit comes with Internal and external wiring harness and plug.
A vacuum switch.
A 4th gear pressure switch.
And good instructions. (Rare)
It works good. The metered vacuum from the Holly carb is just right for my setup.
vicrod
Old 02-20-2006, 12:52 PM
Jmark's Avatar
Any of the kits will work on 4th gear lockup. I've seen them on Ebay for 15 bucks and Painless sells a super kit for $120. All that is really needed is a 4th gear pressure switch sending a signal to the lockup solonoid. You're current 700 should have both in it already and you can set it up without spending any money if you like.
Here are a few different ways to do it.
Mark
700r4 or 350 lockup oldschool Transmission - Rearend 2 01-09-2006 04:25 PM
700R4 Lockup question AngliaBob Transmission - Rearend 2 05-08-2005 11:55 AM
700R4 non lockup Jagwar Transmission - Rearend 0 04-12-2004 10:22 PM
700r4 parts and lockup wiring McDeuce Transmission - Rearend 17 12-17-2003 07:52 PM
700r4 lockup, 81 camaro MDFbodies Transmission - Rearend 1 05-25-2003 06:59 AM
