700r4 lockup - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 06:57 PM
runn141's Avatar
SB S10
700r4 lockup
if use a non lockup torque converter on a 700r4 will it eliminate the need for a lockup wiring kit? this will be on a non computer car.
Old 09-02-2006, 09:09 PM
Jmark's Avatar
Yes..............
Old 09-05-2006, 10:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the tranny must be configured to run without a lock up clutch inside the converter for proper oil flow.
Old 09-06-2006, 07:40 AM
astroracer's Avatar
Why do you want to do this? A lock-up wiring kit is going to be cheaper then a new convertor if money is the issue. There are websites that show you how to make your own wiring kit for pretty cheap also, do a search...
Mark
For what it's worth, 2-3 lockup 700R4 good for 1 MPG LanceM Transmission - Rearend 2 06-22-2006 05:43 PM
700r4 or 350 lockup oldschool Transmission - Rearend 2 01-09-2006 05:25 PM
700R4 Lockup question AngliaBob Transmission - Rearend 2 05-08-2005 12:55 PM
700R4 non lockup Jagwar Transmission - Rearend 0 04-12-2004 11:22 PM
700r4 parts and lockup wiring McDeuce Transmission - Rearend 17 12-17-2003 08:52 PM
