700r4 lockup confusion - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2008, 12:05 AM
I know there are many posts on 700r4 lockup wiring, but most dont explain if wiring inside needs to be changed with the schematics I am finding. Here is my setup, 1987 s10 blazer with carbed 350 and 1990 700r4 from a 1990 1500, here is my problem, from what I can see in any schematic I find about lockup wiring, terminal a is 12 volts and b and d ground out to either lock 4th or 2, 3, 4, I have a normally closed brake switch (no power with brake applied) feeding the tcc 12v to terminal a when I ground terminal b no problems but when I ground terminal d it blows my fuse for guages and brake switch. I know I should probably pull the pan and check it out, but it was working fine with a tbi unit that was recently removed.
Any ideas?
Old 06-18-2008, 01:02 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Front outer terminal +12v switched
Rear outer terminal can be grounded if you desire lockup in 2, 3, as well as 4.
Switch must be a normally open (pic) It grounds upon 4th gear pressure, thus closing the circuit for the....
TCC solenoid (pic) measures 20 ohms at the solenoid +/- a few ohms
Your TCC solenoid could be stuck open and/ or shorted.
ID:	30707   Click image for larger version
Old 06-18-2008, 01:31 AM
Should the inner terminal be grounded as well or is this related to the self grounding switch I have read about and therefore be unnecessary? I will be wiring a switch and would like to be able to switch between 2 3 4, 4 and off, Also is it possible to test the solenoid through the external plug or am I stuck removing pan? Sounds like the solenoid is a good possibilty.
Old 06-18-2008, 01:49 AM
C-10's Avatar
Revolution Calling
You can test the solenoid with +12v at the front outer terminal. You should be able to hear it click.
The outer two terminals are the only ones you need for the way you want to configure your lockup.
You can check solenoid resistance at the case plug too, it should have more than 20 ohms (25?) due to the extra wire and connections.
700r4 manual lockup switch Boosted89RS Transmission - Rearend 8 03-25-2008 10:52 AM
700r4 lockup engaged directly after shift into second?? ferociousd Transmission - Rearend 3 07-22-2007 09:32 PM
700r4 lockup? holoffs Transmission - Rearend 5 05-15-2007 01:07 PM
700r4 or 350 lockup oldschool Transmission - Rearend 2 01-09-2006 04:25 PM
700R4 non lockup Jagwar Transmission - Rearend 0 04-12-2004 10:22 PM
