700r4 , lockup converter electrical questions
I am swapping from a TH350 to a 700r4 and have read most of the 700r4 tech I could possibly read. My driveshaft snapped in half and destroyed the TH350 bellhousing and a section of my flooring. Lesson learned...use a driveshaft safety loop.
The 700r4 I have is from 1985 and does not have the auxiliary valve body. I have spent 850$ in getting it fully rebuilt. I wanted to keep the lockup and this trans was owned by 2 different guys prior to me getting it. Here are the parts in it: -Full rebuild kit (3-4 gear uses 6 clutches) -Kevlar band -13 vein pump -Corvette Servo -New lockup solenoid -New Reverse input drum -"Beast" Sunshell -.500 input boost valve with larger output valve -Transgo shift kit -New TV cable My question is dealing with the wiring itself. I was reading installation instructions for the painless wiring kit (http://www.painlesswiring.com/Manuals/60109.pdf). What confuses me is that I don't have the 4th gear pressure switch or any wiring by the servo. The only wiring I have in the pan is going from the lockup solenoid to the factory plug. So is the 4th gear pressure switch necessary? Am I missing anything, as far as you can see by the pics, that is a necessity for the electrical system that is paramount to operating this transmission? Is it possible to put in an auxiliary valve body and are there any benefits or will I be fine with what I have? My plan was to route the 12v source wire from the transmission up to the brake pedal then to the toggle switch. But looking at painless wiring, there is a vacuum operated switch as well which threw a wrench into my thought process.
not sure this helps, the pressure switch commonly used is a N-Open self grounding switch. Ground wire from solenoid is wired to switch. lock up of the converter in 4th gear only when switch is located in v-body hole near acculilator . your method of wire you can control lockup in most gears as desired. I never see a need for vacuum switch in the hook ups. Wire through brake lite switch is fine... a common brake lite switch with dual poles for crusie control works well
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| 700r4 Torque converter lockup coming on and off | chevy_c10 | Transmission - Rearend | 4 | 05-04-2010 07:43 PM |
| 700r4 Lockup ? | steven_1104235 | Transmission - Rearend | 3 | 03-29-2010 04:42 AM |
| 700R4 into 1956 Dodge questions | jsrail | Transmission - Rearend | 5 | 02-19-2010 09:32 PM |
| 700r4 lockup | runn141 | Transmission - Rearend | 3 | 09-06-2006 06:40 AM |
| Torque Converter Lockup at Low Speeds | JohnTN | Transmission - Rearend | 5 | 09-15-2005 06:05 PM |
