700R4 lockup converter help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2008, 12:01 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I'm making a custon installation of a 700R4 and need to know what should I do with the lockup converter?
can I wire a switch to connect and disconnect at will?
is it worth doing so?
can I just ignore it?
will it help improve millage?
is the solenoid 12V?
I know that if I forget to switch it off the motor will stall if I stop, but will the tranny change gears with the converter locked or it must be disconected for it to work smoothly, switch it on on the highway only?
what if I switch it on on first gear while accelerating?
sorry too many questions but I need too many answers.
thanks in advance.
Augusto.
Old 01-21-2008, 02:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks in advance.
Augusto.
700 trans will not lock up the converter inn first gear.... no oil pressure is provided for that.'
solenoid is 12 volts.
converter needs to be locked up in over drive to avoid over heating the trans.
Old 01-21-2008, 02:24 PM
justold's Avatar
You can wire it through the brake light switch with a relay so when the brakes are applied you drop power to the trans .
The trans will will work on its own ,when it comes to temperature it will lock up when it goes into 3rd gear and unlock when you apply the brakes .I don't have a wiring diagram but if memory serves me right you run the hot + to the trans and switch the ground - I beleave there is a thread about this on this site . Hope this helps
700r4 lockup engaged directly after shift into second?? ferociousd Transmission - Rearend 3 07-22-2007 09:32 PM
700r4 or 350 lockup oldschool Transmission - Rearend 2 01-09-2006 04:25 PM
Torque Converter Lockup at Low Speeds JohnTN Transmission - Rearend 5 09-15-2005 06:05 PM
raising torque converter lockup hueysrod Transmission - Rearend 11 06-10-2005 09:26 PM
700R4 with slipping converter clutch CleviteKid Transmission - Rearend 1 08-28-2004 05:56 AM
